I don't care if it's "Good enough to get me there"...I want it RIGHT dammit!
Knightmare
Ok sorry, never came here to blow off steam yet but I felt the need to today.
For the last few months, I've been tinkering on my car, attempting to get it right. For those of you who do not know, the original motor blew and I put a salvage yard motor in. After the swap, it would not fire my stepfather and I worked on that for a while(Want to say thank you to BillBoost and the many others who offered assistance on that one). Once we got that problem situated, it was still running rough as hell and had an exhaust leak. Fast forward, exhaust leak fixed but I began hearing a backfire in the exhaust. Scanned codes found codes for TPS as well as MAF, replaced all sensors on the throttle body, still has a miss but idles better now. I hooked up a scanner again to monitor the live data, number 3 is missing like crazy(the current miss field gets as high as 188) unless I am giving it throttle. I am the first to admit I do not know much about cars, but I am attempting to learn.
I went out there to day and I have tried different wires, tried a different coil and no change. while I am outside, my stepfather comes up and says "How's it coming?" So I tell him the situation about how number three misses at idle but goes away when given moderate throttle. When cruising down the road, the miss is minimal. He says "So, what's the problem?" I told him that it keeps throwing the SES light and his suggestion? electrical tape over my SES light. "As long as it is getting you from A to B, I would let it ride"...
Sorry, I know that is how you may let your cars operate, but I don't want it to be "point a to point b...but with problems" I want it to run RIGHT dammit!
If there is something wrong, I want to fix it...bottom line.
Ok sorry, just had to let that out lol.
Re: I don't care if it's "Good enough to get me there"...I want it RIGHT dammit!
Have you swapped the injector yet?
not yet..next on my list, but the rest of my day is shot now that my daughter is home from school lol. My next day off is Friday, I intend on swapping it then
Check around for vacuum leaks when you do that. Might be a simple fix like an injector oring is torn.
will definitely do that sir, thank you :) I'm not sure if it's a normal thing or not, but when scanning the live data, the injector status for # 3 would go from off to "stuck low" not sure what that's all about lol
Make sure the connection is on really tight. Pull it off and make sure when you put it back on it goes on tight and clicks.
Check the resistance of the thing.
If its less or more than 15-16 ohms, its shot.
I'd look at it in this order:
Plug and wire
Coil pack (yes..I have seen only one tower fire)
ICM (Yes..I have seen an ICM not fire one cylinder)
Injector
Poofed Piston
Do you have the metal dust boots over wires still?
Number three does not...a couple of.others do.
Plug and wire
Injector
Poofed Piston
Checked wire already...did not pull plug yet...also switched out coil...gonna completely check everything on the list...you have never steered me wrong sir
Sent from my LGL55C using Tapatalk 2
I don't really steer...it's more like shoot from the hip or wing it. :th_thumbsup-wink:
You havent even pulled the plug yet?
