87IROCZOWNER69
SO how does one go about bleeding the brakes on a 99 Grand Prix? Becasue pumping them only gets you so far.....
or you can use some talent and use the power seats and a 2x4 to push the brake while you bleed....wad up
Rednecking works when you are by yourself.
I pulled out my power bleeder on Friday and there's just nothing like it. Absolutely one of the better tools in the universe.
Did you start at the rear right wheel and pump it a ton of times, then the rear left, front right and front left? I usually use close to a big bottle of fluid in the process.
If it's mushy..you still have air in the system or a problem with another line.
We never asked why you were bleeding. Soooo why were you bleeding? If you replaced the master cylinder..it takes a bit to clear the lines and have them bleed fully. Especially one brake pump at a time.
I'm pretty spoiled with the bleeder. It's so nice and quick. fluid flows right out and when it stops bubbling etc I let it go a little further to get clean fluid..then done. next wheel etc.
Take a moment and do the filter. Shouldn't be too bad.
Then bleed the lines. Overall brake lines aren't tough for me. The tough part is getting into the tight spaces to flare them.
Random misfire on 2.7 intrepid? I'd get rid of it.
