Hopefully this might help, it reads as if you might be able to do it without using the scan tool to monitor and learn yourself, but I'm not sure, we haven't had to do it at the dealership on a GXP yet.
Throttle/Idle Learn
Description
The engine control module (ECM) learns the airflow through the throttle body to ensure the correct idle. The learned airflow values are stored within the ECM. These values are learned to adjust for production variation and will continuously learn during the life of the vehicle to compensate for reduced airflow due to throttle body coking. Anytime the throttle body airflow rate changes, for example due to cleaning or replacing, the values must be relearned.
An engine that had a heavily coked throttle body that has been cleaned or replaced may take several drive cycles to learn out the coking. To accelerate the process, the scan tool has the ability to reset all learned values back to zero. A new ECM will also have values set to zero.
The idle may be unstable or a DTC may set if the learned values do not match the actual airflow.
Conditions for Running the Throttle Learn Procedure
Reset Procedure
[TABLE="width: 95%, align: center"]
[TR]
[TD="width: 1"]• [/TD]
[TD]DTCs P0068, P0101, P0102, P0103, P0106, P0107, P0108, P0116, P0117, P0118, P0120, P0122, P0123, P0128, P0171, P0172, P0174, P0175, P0201, P0202, P0203, P0204, P0205, P0206, P0220, P0222, P0223, P0300, P0351, P0352, P0353, P0496, P0601, P0604, P0606, P060D, P0641, P0651, P1516, P2101, P2119, P2120, P2122, P2123, P2125, P2127, P2128, P2135, P2138, or P2176 are not set.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]Ignition ON, engine OFF.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]The vehicle speed sensor (VSS) is 0 km/h (0 mph).[/TD]
[/TR]
[/TABLE]
Learn Procedure
[TR]
[/TR]
[/TABLE]
[TR]
[TD]The engine speed is between 450–4,000 RPM.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]The manifold absolute pressure (MAP) is greater than 5 kPa.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]The mass air flow (MAF) is greater than 2 g/s.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]The ignition voltage is greater than 10 volts.[/TD]
[/TR]
[/TABLE]
Throttle Learn
Reset Procedure (Performed after the throttle body is cleaned or replaced)
[TR]
[TD="width: 15"]1. [/TD]
[TD]Ignition ON, engine OFF, perform the Idle Learn Reset in Module Setup with a scan tool.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]2. [/TD]
[TD]Start the engine and monitor the TB Idle Airflow Compensation parameter. The TB Idle Airflow Compensation value should equal 0 percent and the engine should be idling at a normal idle speed.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]3. [/TD]
[TD]Clear the DTCs and return to the diagnostic that referred you here.[/TD]
[/TR]
[/TABLE]
Learn Procedure (Performed after the ECM is flashed or replaced)
[TR]
[TD="width: 15"][/TD]
[TD]
Note: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code (DTC) List - Vehicle .[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
1. [/TD]
[TD]
Start and idle the engine for 3 minutes.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
2. [/TD]
[TD]
With a scan tool, monitor the Desired Idle Speed and the actual Engine Speed.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
3. [/TD]
[TD]
The ECM will start to learn the new idle cells and Desired Idle Speed should start to decrease.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
4. [/TD]
[TD]
Ignition OFF for 60 seconds.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
5. [/TD]
[TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
6. [/TD]
[TD]
After the 3 minute run time the engine should be idling normal.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 10"][/TD]
[TD]
Note: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 18"]⇒[/TD]
[TD]If the engine idle speed has not been learned the vehicle will need to be driven at speeds above 70 km/h (44 mph) with several decelerations and extended idles.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
7. [/TD]
[TD]
After the drive cycle, the engine should be idling normally.[/TD]
[/TR]
[/TABLE]
[TR]
[TD]If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds and repeat step 6.[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 15"]
8. [/TD]
[TD]
Once the engine speed has returned to normal, clear DTCs and return to the diagnostic that referred you here.[/TD]
[/TR]
[/TABLE]
