MAP Sensor problems on Swap
SgtCebo
Just wondering how to connect a L67 MAP sensor to a GT wire set? The gtp one uses 3 wires and the gt one uses 2. Can i leave a wire out or just run 2 to 1?
You sure its the right sensor? Mine hooked right up, except i needed an extension because the L67 map sensor is behind the SC whereas the GT is in front.
Ya its the right one. i just bought one from autozone. the only MAP sensor has 2 wires and went on top of the plastic intake. theirs no plug for this anywhere
Heres the difference.
is the L67
is the L36
I have an L36 and L67 MAP, they both use three pins.
Just slightly different connectors.
Well mines just a POS then cause one the old sensor has 2 and the gtp sensor i have has 3. i do have the connector that i cut off a gtp at a junk yard. but theirs 3 wires where as the one i have on the car has 2.
