It is because aluminum rims can flex and the lugs can come lose even if they are torqued to spec. How are we to know if the last guy that put on the lug nuts didn't over tighten(impact wrench full blast) them and strech the threads? You think a wheel stud is somehow diffrent then any other bolt that can get worn out? I have torqued my wheels down and rechecked them a few weeks later and have one of the 5 come loose.
So crap like "It's not like the monkey zipping them on your wheels got the job because of his physics degree." and "make sure retard that worked on your car didnt screw up" is something only ignorant dumb sh!ts would say. Guess what, this monkey wrenching retard DID go to school to learn how to fix cars. Ever have your scanner tell you a body controller was going bad? Probably not, all it does is give you a pile of codes and some retard that spent four years in school has to make the connection, or spend hours chasing down a bad wire thats making your dash lights flash. One of the guys I work with literaly has a genius level IQ And holds degrees in Automotive repair and houeshold electronics, not to mention all his ASE certs.. Next time your feeling smart go try out a ASE test. You'll learn in a hurry we arn't all a bunch of retards. Jacka$$....
