Wheels!?!?!
Need to find 5x115mm for an exact fit.
Mustang/Eclipse/ etc... use 5x114.3mm and they will fit fine, most recommend hub-centric rings when going this option just to be safe.
One person used the regular nissan 350Z wheels.
They seem to fit alright, would need to find out if the other styles would work. Backspacing issues could cause rubbing &/or a ghetto look that would get you laughed at.
^ Are the same bolt pattern, and look similar (at least to me) to the new Camaro wheels. They are staggered so offset may become a problem. Just something to look into.
It would be more expensive to buy OEM wheels like those than it would be to find an aftermarket wheel that will fit properly for way cheaper.
FR500 Mustang wheels from the GT500s. Staggered 18s I know for sure, think there are aftermarket 20 options if you really need to go that route.
youre avoiding heavy wheels, but were interested in the camaro 20s. now you're posting a 20x10 FR500 that 98% of the people out there couldnt even fit on this car.
does not compute.
not necessarily 20x10. im talking about design. maybe 18s and 19s at most. and the camaro 20s arent as heavy as most oem 20s out there.
if you gave us a better understanding of what you'd actually want a bunch of us could recommend styles and sizes that would probably work for you.
but you havent.
obviously not chrome and obviously nothing too heavy. basically open for any suggestions. and those replica fr500 are built using "low pressure casting" that means they are not as heavy.
Eclipse have a smaller hub bore so that is something you have to watch too. Just because its a 114.3 doesn't mean it will fit a GP.
