Mike Kopstain
So I've kind of stayed out of this but after discussing it with some other people prominent in this community (and others), absolutely no one can fathom how this would make any kind of substantial difference. I haven't taken a dremel to a blower either (we CNC port) and I don't play an internet know-it-all but the basic premise behind the way this product is advertised as working just isn't sound, at least to the point where it would make anything but a nominal difference in outlet temperatures. It's akin to putting ice on the blower between runs only you're just putting ice on the snout and it's not ice... it's a cup of room temperature water. I mean it just doesn't pass the sniff test at it's most basic level and then to see all these posts trying to complicate something that's so simple just kind of makes it smell even more like a load of bull****. We all kind of got a giggle that it got this far in the production process because it's just so unbelievable.
Perhaps the platform this was tested on has an issue where the blower snout is so close to another heat source that it absorbs some of that heat and maybe on that particular application cooling the snout accomplishes something but even if that's the case, this would be a complicated solution to a simple problem.
We've never had anyone question a product when we put up clear and concise before and after numbers. Is there a demonstration or log of outlet temperatures pre and post cooler? If so can you provide links to that info?
