footballplaya3k
Will do. Thanks for the help.
Just to make sure, i have a gen V with L32 LIM and L67 throttle body. I do not have EVAP or EGR. Also i'm not intercooled.
Is it fine to run a hose from the back of the pcv nipple on the back of the supercharger to the nipple sticking out in the front that use to be used for the EVAP????
On an L67 Tb. The plug on top of the TB. Does that connect to the IAC?
You are putting a N* on a gen 3. The Intercooler isn't an issue because you have the groove and drilled core from ZZP. You need an adapter plate to bolt the N* up. I'm not sure how the adapter plates work in this case. Who's adapter plate do you have? What do they say about pcv?
No sir,I'm going to be using a gen v blower on my modified lim for The gen 3 Stg 2 ic,The n* will be on The gen v. Will my gen v blower pcv fuction be ok using The gen 3 lim and ic?
Yes, PCV will work with tiny groove LIM. The gen 5 will work with the gen 3 LIM. Connect nipple on the back of gen 5 to nipple on N* to get PCV to work.
