ShadowSwept
Hmm... How difficult would it be to swap ABS from an equipped GT to a non-equipped SE and make both fully functional? I imagine a tune would be involved but other than that could I do a straight hardware swap? Both are 03.
ABS sucks.
I'd delete the ABS if I cared enough to tear the brake system totally off.
Almost hit someone in the snow because of ABS.
I learned to drive on an old three on the tree pickup, and a mid 80's buick...the LOL's at thinking you had something to save you besides your right foot in a bad situation.
ABS also didn't help in a panic situation in my Cobalt wreck, granted, non-ABS equipped cars wouldnt have helped either. It's all personal preference.
Next time youre in some snow or ice, give it a shot. ABS just makes you slide all over the place, pumping the brakes...always seemed to work for me, so it's whatevs.
when i crashed my truck i was on dry flat pavement, (4 wheel abs) nailed the bakes and the pedal went to the floor, all i felt was the pedal pulsing and heard the abs grinding, needless to say i just rolled at almost the same speed i started braking and then slammed the crap out of the other car.
after the hit, my front wheel was under my truck and i drifted into the middle of the intersection. waited for cops and a tow truck.
the ifs in the gm trucks, well yeah the weak link is that wheels come off pretty easy, tore it off again while snow plowing, the wheel hit a wall between garage doors and it twisted the wheel right off. another night where i made money only to sink it back into the truck.
I don't believe you understand how ABS works and/or what its supposes to do. It won't stop you sooner.....it allows your wheels to keep a small amount of traction on the roadway, primarily for control purposes.
Sent from my DROID RAZR using Tapatalk 2
Cop has no senses.
Therefore,
ABS works perfect.
i fully understand how abs works and why i dont like it so much, if you have no where to turn, (no escape route) you simply plow into what ever you wanted to avoid. and lets face it, when braking fully, your steering is not that great even with abs.
im my case, if the wheels had locked up i defiantly would have stopped before i hit the other car.
i have had lots of cars with out abs, only 3 with it so far, and have had more problems hitting stuff with abs, its not a perfect braking system by a long shot yet.
and a good driver with no abs will be able to deal with a real braking situation just fine. in any road conditions. where these abs system leave you on a tow truck for sure sometimes.
pumping the brakes does work well, and you have the control to push as hard as you need to, and let up a bit if you lock up the wheels. unlike abs where it takes all the fun out of driving. aka took the brakes away from your foot and your senses.
None of the tests done over the last 20+ years take into consideration the caliber of racekar driver we have here at gpf.com
A locked up vehicle will rake longer to stop than a vehicle using less braking power with reaction
