Discount tire, there's your first problem...LOL
MRW - How to measure bolt pattern
From center to outside of opposing hole. Like I said, the 0.7mm is minute, but does make a difference. Not enough distance to be overly concerned in my opinion. That is the purpose of the hubcentric to reduce stress on any lug that may have uneven pulling pressure from the wheel not being centered.
I only went there cuz theyre one of the only TSW wheel distributors around me. Come to find out my wheel that is bent is discontinued.....fml.
I just had a guy from discount tire tell me that he wouldnt mount a 114.3 wheel on my car........then i walked out laughing.
But you dont need hubcentric rings to run mustang wheels. Since there hub bore is almost the same diameter as ours. Thats why running 114.3 rims is no big deal.
Fronts are 18x8 and rears are 18x9, and riding on B&G springs.
I wouldn't use 114.3mm.
But I also wouldn't trust using sleeves over the caliper bolts, as many do when upgrading calipers.
they are the 'same' because they are so close they dont have to consider them different.
however, in the real world they are different.
