Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
I just bought a 04 Grand Prix and it is losing antifreeze and there is a strong exhaust smell in the overflow tank. It seems like it is burning it thru the exhaust and idles ruff. Any ideas???
If you pull the radiator cap off, do you see exhaust bubblining in there? The overflow may be tough to check for the smell because a downpipe leak may be close enough to smell. Also I wouldn't trust the smell of most overflows. Seeing it in the radiator, that I would trust.
So it is the 3800? This is so rare that we're going to wait until someone else chimes in 'cause I don't even know where to start.
How many miles are on it?
I'd start with the LIM gaskets anyway. I just had to do the LIM on my sons 2003 Impala that he just got two weeks ago from his grandma. it only has 43000 miles on it.
Really...I'd look to see if it had aluminum gaskets first.
I'd start by taking off the rad cap and bringing it up to temp. Look for bubbles in the radiator. It's the single easiest HG test you can do, and pretty damn accurate too. LIM gaskets might consume some coolant, but it's not typically much at all. Now..since you say 3800 S2 and not saying supercharged, I can toss this at you to check. This is one of the most common issues with a non charged 3800 using coolant. http://www.grandprixforums.net/97-03-na-l36-uim-failure-60667.html
It would be relatively cheap to pull the upper, drill and plug the LIM (even on the car. Then keep on motoring til the engine finally blows. Plugging into in this thread http://www.grandprixforums.net/how-mod-lim-46931.html
Is plugging really a good thing on the motor, not really. You can get some metal shavings in the coolant. Likely it won't hurt a thing though. I would do it in the case you are describing.
I see what your saying with the UIM but that would have to be one heck of a hole in the plastic manifold to get that much exhaust in the cooling system. Possible though.
Mine had a pinhole or two but there wasn't even any bubbles in the rad. It was just using coolant...had to refill every two or three days.
Chuck..no amount of hole would get exhaust in rad. In case he's incorrectly diagnosing the exhaust in teh coolant and he's just loosing, then this applies. I suggest testing and looking to confirm first.
I did notice now that sometimes when it idles there is a steamy smoke like from the exhaust. But when u start it it dies the first time or 2 then it runs alittle better. I got it for $1600 dollars so i figured if i had to put a motor in it it wouldnt be too bad cause the body and interior is in exclent shape.
