Frost White GTP
Re: 97 White GTP Coupe "Now White On White!"
i didnt like those rims, but you painted them white now i actually really like them
thanks, they were not the rims i wanted to go with but they were a good deal so i grabbed them, any rims i bought were going white though unless they were chrome. scince i got the car i always wanted white rims i love the white on white look
car would be perfect without the chrome projector headlights.
amazing looking car!
Good looking car lug nut covers worked out good for you then?
thanks man! and i got them headlights for free so cant complain i had the black covers on my old beat ones but they dont fit over the projects so i couldn't use them sadly
yea worked out great thanks alot it was a real help :)
If you don't want it low than get some vogtlands and KYB GR2's/Excel G's. That will sit around 1" and ride close to stock. Eibachs are known to be one of the roughest riding springs.
eibachs have a progressive spring rate. SSC's will be as rough, if not rougher.
i still have time to think mainly i just want to get rid of most of the wheel gap is all
whered you get that hood? or did you make it yourself?
I got it from pfyc.com last year, the problem with making hoods yourself is that once you put a type of fiber glass over a metal hood the vibration will cause the body filler or fiber glass to crack even if you rivet it in. The only really good way to make a hood is if you have a metal hood and metal scoops. But you want the same metals or else you will have galvanic corrosion. Trust me if i had a scoop laying around i would of made it myself. Plus i wanted a functional ram air it would be alot of work to make one. Though id never doubt myself i know i could do it;)
yes have the SD ram air hood with the SLP cold air/ram air box from 3800performance.com and it does show a very noticeable difference in temperature im running a stock t-stat as of right now
Its going to look sweet with a drop. You've got me thinking now, I might have to see if i can pick some of those up and do a gloss black....
