Frost White GTP
Re: 97 White GTP Coupe "Wheels Now White!"
So today was a very productive day i accomplished a lot and gave my Grand Prix a whole new appearance check it out!
put the mud flaps on had to do a lil customizing to make them fit a lil better so the tires wouldn't rub.
How did you put these on? I got my pair from Swiggles, screws?
Re: 97 GTP White on White "exhaust video added!"
How did you get your car to sound like that? also where did you get your mud flaps?
zzp 2 1/2" down pipe no cat
thrush glasspack resonator
stock mufflers
mudflaps from brandonl2000
yea i had to customize them a bit i used some extra screws from the bin in the shop i had to drill all my own holes in the back, the front i used the 2 that hold the side skirts on and the one above it that's holds the plastic fender well in, but had to use longer bolts and had to cut the edge a bit so the tire didn't rubs (fronts). i was going to buy swiggles but he only had a pair and i wanted a set. i did want the grand prix ones though lol
That's what I thought, may go with Pontiac ones in the front.
id try and get them all to match IMO but it would defiantly be different, the hardest part of the install is getting the correct position and making sure the mud flap is covering the wheel and is not crooked i didn't do a perfect job lol but it looks alrightt
not a bad idea to get them lined up lol i made templates
i have to disagree mud flaps set your car off a little more IMO
Everyone likes different things. Mine are going to get tore up to being lowered and the nonfriendlytoloweredcars roads we heave here
ooh i like the mudflaps. gonna get a set for my car soon.
Hmmm...I might have to get a few pairs of these...
Eddie, I should hate you for making me spend more money on my car lol.
But thanks for the inspiration :)
yea mine probably will to once i lower it
haha your car will look great with them!
hope to see them on there soon :th_thumbsup-wink: lol
sounds great dude!
thanks man!
That actually sounds good.
thanks! yea i know most 3800's don't sound to great with exhaust without major mods and a cam
that's why i kept stock mufflers i didn't wanna change up the sound to much but needed more flow mods plus my exhaust was leaking bad anyway
i redid the whole exhaust i got newer stock mufflers from a 40th ann./special edition grand prix (im sure there all the same) grinded them down with a wire wheel and primed them with high heat primer and painted them with high heat low gloss black did the same for my old piping and put the resonator in i did it at work my boss' son and the other guy i worked with all helped me out
where did you get your tinted head light and tail light covers?
don't have head light covers anymore since i went to projectors.
tail lights are not covers there 20% tint film over them.
if your tinting your tails i suggest you use VHT nightshades spray tint you can get it at Autozone.
check the VHT nightshades thread out in the visual body modifications section.
ordered 40th Anniversary dash trim, shifter trim, and 40th Anniversary floor mats today :th_thumbsup-wink:
