Top swapped L26 goes BOOM :D
Will do that tomorrow. Yes the SES light came on about 10-15 min after the bogging, I'll go to Azone and scan that after checking the plugs.
According to a lot of info and write ups on GP forums, the mods I have should be just fine with a 3.4... (I did however forget to mention that I have 1.9 rockers in the first post).
But yeah, productive post guy :)
You said you have a genV though... gen III and gen V are 2 different animals, and running a 3.4" on a gen v needs a lot more than a gen III with the same pulley.
Not to mention, I believe top swapped cars have higher compression as well, so all that together, you'd need more supporting mods than a stock gtp with a gen III
So you have headers, bigger injectors, rockers, and a zzp tune that you dont even know what is has done, with a gen V and 3.4 pulley.
I think most people with that setup would also want a cam and intercooler... and be scanning every day.
In his pics of his engine hes showing a Gen3! He never said that he had one he just didnt know what Gen supercharger it was. The way you can tell if its a Gen3 or 5 is the bolt hole on top of the supercharger housing that a stock L67 fuel rail bolts to.
In his pics of his engine hes showing a Gen3! He never said that he had one he just didnt know what Gen supercharger it was. The way you can tell if its a Gen3 or 5 is the bolt hole on top of the supercharger housing that a stock L67 fuel rail bolts to and that does have the bolt hole.
My bad, I read too quick... but still, a 3.4 without knowing what's in the tune, and not scanning, kinda invites the "eye roll" smiley.
If I was gunna buy an already modded car I'd make sure I had the proper equipment to run it safely before I got into it, especially on a top swapped car instead of a modded gtp.
Yes I know, not the smartest thing ever. I did buy a DHP tuner and have been looking for a '99 stock pcm to swap in and start tuning. Ok off to scan the code and check the plugs!
Once you have a DHP, all you need is a pcm that'll work. Stock files can be found at BPro...should be plenty of DHP happy binners
Well this morning I tried pulling the front plugs, but epic fail. I gave up on that and scanned at Autozone, got a misfire code :rolleyes:
Got my oil changed, old oil was dirty as hell. Engine now has significantly more oil pressure. I had a few guys from a local speed shop take a look and listen, as well as my main mechanic. The guys from the shop wanted me to bring it in for a better diagnosis ($$$), my mechanic says that it sounds like sticky lifters.
I floored it a few times today and nothing abnormal, it runs fine apart from the damn clanking. Engine runs warmer after the oil change, hmm...
This sorta makes me want to throw an XP cam on and go through the valvetrain, but the body of this car is on the verge of rusting away soon.
