Below Average Joe
Need something better on gas. I love it, but i'm getting the itch to move on.
You mean the Camaro? M/T Drag Radials. The trucky thing, NT420's.
Finally checked the tranny fluid after work. Just a little low from the change.
Good job, you broked it!!! :th_shakinghead2:
j/k Is it leaking underneath???
Haha. No leakage from that area that I see. I only put 6 in it originally and ran it for awhile to get things flowing again. Just forgot to check it until today.
It is getting new plugs and wires in the near future, so maybe we'll find something then. Idk.i had a pretty bad oil leak in my eyes, leaving a 3 inch a 2 inch and a 1 inch puddle everywhere i parked, i just changed my valve cover gaskets and im all dry now, i had oil dripping off every oil pan bolt the trans pan was coated in oil, oil dripping out off the motor mount, everywhere lol, dry now.
i knew i was on the right track when i pulled the plug wires off in the rear and they all had fresh oil all over them.
I have a nickle sized spot everyday when i leave work. It appears to only be concentrated around the pan, but idk. It sure got nasty again pretty quickly after I cleaned under there.
