no fluid to rr caliper help
truefate
Need some help. I just bought a 97 gtp. The previous owner replaced the m/c a few months before I bought it. He advised me that the brakes were soft and it needed to be bled. No problem. I bled the ABS modulator valve then went to the rear brakes. I have no pressure in the rear right caliper and the left had a frozen bleeder valve. Its old so I said to hell with it and bought new calipers for the rear. The left bled fine...the right still has no pressure. I checked the front, they have pressure. I pushed fluid through the caliper with the line disconnected, all good. Pushed fluids through the caliper with the line conneceted...no go. Dissconneced the line @ the modulator valve and pushed fluid through..no problem. The issue seemed to be the modulator valve but I was under the impression. That the rear lines were run off a single valve unlike the front. Is this wrong. Is it possible something I missed. Can the modulator valve be rebuilt? What are my options. A new modulator valve is $5000...I rather not spend that if I don't have to. Any help would be great
Did you try starting the car and bleeding them? Maybe there is a little blockage and the extra pressure will help you bleed them.
Yeh tried that too. I tried everything I could think of. Pressure bleeding vacuumed bleeding... nothing from thar line as long as its connected to the valve body.
Dropped it off to my mechanic for an alignment today. He's gonna take a look @ it for a second oppinion. Hopefully I've been over thinking it and its something simple and cheap
