i dont have a clue but since so many ppl have viewed and no one helped i'll offer suggestions. are you sure you have power going to those light sockets?
Pull the cluster again.. Pull the circuite board out and look at all solder points. Check for non clean points (dry solder points).. If you see bad ones, heat with soldeirng iron, add fresh solder and test.
