rodneypierce
Alright guys, I just picked up a 98 GTP with the standard (non-bose) audio system, and its horrid. So, how about I get some help from my fellow GP addicts. I dont want to spend a penny over 600.00 (less would be better). I need the following:
5.25 Door Speakers
6x9 Deck Speakers
Head Unit (with mounting kit, harness and antenna adapter, usually free with purchase)
10 inch sealed sub box. (sub is rated for .81 cu ft)
4 gauge amp install kit w/speaker wire (enough for all 4 speakers, to the trunk)
I current have an MB Quart PB 5400 5 channel amp which is 55 watts RMS per channel, and 200 watts RMS for the sub. I also have the 10" woofer covered with an MB Quart DWG 254 DVC. I will be wiring it at 2 ohms, which will net me 300 watts RMS from the amp. Sub is rated at 250 watts. So should be alright.
Now, here is what I want. Would rather have coaxial speakers, but am not totally against component sets for the doors. Head Unit must have a multi color display (so I can change it to red to match the interior color). Other then that, I dont have much else as far as particulars. Let me know what you guys would recommend. Links to each would be helpful as well!
**Edit, music choice. I listen to metal/hard rock 98% of the time.**
5.25 Door Speakers
6x9 Deck Speakers
