mount it and hook up the shift cable to it. done.
because racekar?
That's nearly Fiat 500 cool.
hmmm
looks cool if you get the one with the butten on the side you could wiring up perf shift to that
i always had an idea of using perf shift as a way to make it a "manual" valve body by proagraiming the seprate perf shift tables to lock out the gears so it acts liek a manual valve body put it in 1 it's 1st gear put it in 2 second gear, exc, exc
or have it be a revears manual D is 1st, 3 is 2nd, 2 is 3rd and 1 is 4th
no idea if it would actualy work though been a few years sense i looked at the shift tables
If you can, just set perf shift points at extreme numbers, so that it will never shift by itself, so when you want to go manual put that **** into performance mode.
Or jusy buy a manuel.....and stop trying to a ricecar driver![]()
^you sure can...might as well get a shopping cart wing and some stickers while we're at it. The b&m on its own isn't a horrid idea, but its an automatic trans, let it do what its designed to do.
