Hotrod373
So i aquired a 1998 GP GTP about 3 months ago and have been very impressed with it.....I took it to the dyno this evening and was kind of dissapointed in the results. Just going by some of the posts i have seen on this forum i was expecting a little bit more with the mods that it has.
It made 199 whp and 250 wtq
Here is a list of the mods that it has that i know of:
Pacesetter headers with down pipe
MSD coil packs and 8.5 mm wires
3.4 modular s/c pulley
Mezeirre electric water pump
the fuel pump resistor delete {or something like that}
alt. voltage booster
flowmaster mufflers
basic ecm mods (egr code delete, fan on of temp for 160 deg thermostat, fan run time of like 3 mins after shut off)
160 degree thermostat
some aftermarket gauges....showing that im making 8lbs of boost (which is what i thaugh they made with a stock 3.8 pulley???)
Northstar TB swap
K and N intake tube and filter
As far as i know it dosent have any internal mods or even a tune on the ecm for the smaller pulley.
The car has 114k and has been VERY well kept....I believe the S/C is the original, but has had just the snout replaced recently, but still with original rotor pack
Let know what you guys think about my dyno numbers and if that seems accurate....Just seems like a lot of money for someone to throw at it for some numbers like that
flowmaster mufflers
Northstar TB swap
