Wheel Swap
xerxescct
I found a donor car with a set of GP GXP wheels, tires, rotors and calipers. I am going to swap these into my 04 comp g. Will this work without any issue? I have seen the caliper swap before but not sure about the wheels.
Anything I should know about before swapping?
Thanks!
Thank you for the quick reply.
This is the wrong forum but I also have the entire front facia and fenders. I had read a while back that the fenders are bolt on and need to be replaced before the facia. Im curious if all the wireing for the fog lamps and such will match up or if I will have todo some modification for it to work.
