Double check everything after installing it. In fact, put cardboard under the car for a few days after you install the external cooler to make sure there's no leaks.
not sure if headers are available.
Aluminum block draws more heat from the combustion chamber.
Transfers more heat to the transmission.
I wouldn't do anything, you will cause more problems messing with it. Look up tripledgeperformance for common tranny problems. None of them are overheating.
Who told you the tranny overheats.
mine ran between 195-210 in the interstate at 75 and around 220 in town. thats why ive put in a trans cooler. brought the temps down to around 170 everywhere.
