HUD not working...
19GTP98
So ever since I bought my GTP the HUD has not been working. When I am in park it works perfectly fine, but as soon as I start to drive it flashes turns off flashes turns off. I have no idea how to fix this or what the problem may be. Anyone with any idea please respond!!:th_winking:
I would like to research this issue further, could you please pm me your name, VIN number and any other information regarding your problem. Has the HUD always flashed or is this a new occurrence? Does it only happen when driving? Does it continue to flash on and off or does it flash a few times then shut off? I look forward to hearing from you.
Louis
GM Customer Service
I have a similar problem exept now it just doesn't work completly will try fuses and my friend said we could swap his out to see if its the hud it sure hope not there kinda pricey.....
the huds have a **** ton of common problems. the springs break that adjust it so it points straight up, the switchs goes bad, sometimes just the hud unit itself goes bad. start cheap (fuses) and work your way up til you find the issue
