I think its from running it with a vac leak...Odd.
yea they did all look the same...vac leak = lean.
not rich.
Did they all look the same?
If so, I'd venture to guess its in the tune.
cool thanks and your pretty much right this is what paul had to sayHold both buttons to get into menu.
Then some parameter option.
then you select what you want to be able to view.
then it reboots, resets your annunciator, and you can now select your selected parameters from the scan feature.
This should help as well: http://www.aeroforcetech.com/files/Interceptor_USER_MANUAL_rev_2_8.pdf
so is it a bad sensor?DTC P0101 Mass Air Flow (MAF) Sensor Performance
The following are general possible causes:
Large Vacuum Leaks, split Intake Air Boot or PCV Hose, defective intake manifold gaskets
Mass Air Flow Sensor (MAF) Circuit and or wiring problems
Defective Barometric Pressure Sensor (possibly bad MAP input for GPs)
Dirty or Contaminated Mass Air Flow Sensing Wire or Filament
PCM software needs to be updated
L67 and L36 have diff mafGuess I could put the one from my old tb in there
