What did you do to your Car today?
Status
Not open for further replies.
We had a bad day.
Put gas in it....15.821 gallons. Whoopsies, a little low.
Then I found the door pillar soaking wet...turns out water is getting in due to s**** weatherstripping. So not only is my door wet, but the Passanger floor is wet too.
Screw you rain 3 days in a row.
Topped off the Windshield Washer Resevoir... and added alittle water to the Coolant Resevoir...
So much work... Im tired :th_laugh-lol2:
At least you found it now... middle of winter would have been worse ;)
Moved my car in the company parking lot away from the warehouse door after saw they were throwing out a bunch of old steel desks and chairs, didn't want the stuff falling on or scratching my car.
:th_wavefinger:
Its been ripped around the door since this summer, I just don't wanna pay $70 to fix it right. So I think I'm just gonna get some sticky sided window/door weatherstripping and stick on the door. Once I realized where it was coming from you could see exactly where it was getting in and running down and out by the little tweeter speaker.
Well, installed 9" spectre filter got rid of my short stubby one that came with ebay intake. Then it started running real funny, replaced vac line and iac.....so far so good!? Then took to shop to check alignment and found out that my rear track bar is bent and cracked. Of course the adjustable more expensive one, pfffft! So now I wait till it comes in to put it on and pray to god it doesn't break. *knocks on wood*
changed that damn water pump finally, and flushed out all the dex, refilled with the green.
painted the new one for chits and giggles.
Status
