Taz Magister
still doing the ssm90 setup? i believe i have an extra balancer laying around somewhere. the spot for the standoff is easy to find too, and the other pulley hangs off the coil pack bracket.
not sure I keep going back and forth, I'm trying to foucusing on getting all the big parts ready first and then figure out the other stuff
I got the tb done and smoothed up the supercharger inlet alittle bit I'm not really sure what all to do to the inlet.
On the outlet I got all the cutting done unless you guys think I should open the triangle up some more. I still need to sand/clean up the corners and where the numbers used to be alittle bit I'm not 100% sure how to go about doing that but I'll find away.
I've pretty much completly given up on the idea of polishing everything on the outside, I still want to make it look nice so I'm either going to do a good job painting it myself or get it powder coated.
I'm thinking of just doing everything ontop (s/c,tb) a similar grey to what the snout is from the factory, then the LIM and outside of the heads in red and maybe the fueal rails in red too even tho they are polished...
