black plague815
Will a bad LIM Gasket cause performance problems?
It is leaking there but I can also see oil underneath the supercharger, on the very top of the intakean external LIM leak is rather uncommon.
Most common external leak are the coolant elbows that connect the water pump to the heater core to the LIM.
i'd venture to say yes.
but primarily it can cause you to chuck a bearing or hydrolock the motor if it gets bad enough.
I guess I have some figuring to do thenon the top of the LIM the only oil it'd be exposed to is from the s/c. not the motor oil.
So if the LIM gasket was bad I would be getting white smoke out of the exhaust from cooland in the cylinders?
