LIM Gasket
would it hurt anything to take the car to the powerwash and spray all that out so that I can keep an accurate eye on it, becuase the oil that is down in there is pretty dark which leads me to believe its been there for a while
on top of the blower, theres a black cap with "PCV" written on it.
remove the two 10 mm bolts and the PCV valve will be under a spring, pull it out and shake it, if it rattles freely then its good. if not, it might be clogged causing pressure to leave elsewhere taking some oil with it.
I will run out and check real quick, Also could I get you to coment on my question on the post entitled O2 sensor under this same forum, if you could. really curious about it
they should have a low pressure engine wash setting.
if not, grab a can of brake clean and clean it with that and a rag.
avoid connectors.
