SeanGTP's Generic GP - Retrofitted Angel Eyes on PG 5
Re: That Black GTP
i love'm. my stocks were faded to hell, had like $60 bulbs in them and barely saw anything. now their so bright i can basically see through things haha
Re: That Black GTP
Just ordered a set. Had to order corners separately, didn't see any sets that came with the white reflectors. Shipping on the headlights was a *****, but that's probably just to make them look cheaper than they were. $110 for the lights total, $32 total for corners.
Re: That Black GTP
yea the seller(s) do that, they'll list the same headlights with different ads that are all basically the same with a bunch of different prices and shipping prices, but all add up to equally about the same across the board
Re: That Black GTP
heads and tails on ebay are pretty much for any car, are the same you could buy at an online retailer for usually a ton less, just with these you have to seal them up more to prevent water from getting in, hence the faint, rough, untrimmed edges on mine
Re: That Black GTP
TADA!
Re: That Black GTP
TWO HEADLIGHTS!?!?!? no way.
No, he just has the amber turn signal bulbs, mine are clear, and when i have the red ones in they'll be black. but if you do the clear/white bulbs they'll blend right in like a dream :th_thumb-up:
Re: That Black GTP
I think the bracket part that holds the assembly to the car is really bent, and I also think this new bumper cover sag a bit over on that side. I'll get it fixed... eventually.
Edit: Look at the driver side corner, and look how it sits crooked compared to the space provided from the fender bumper-cover. Almost proof that it bent.
Re: That Black GTP
I forgot to tell you to reuse the original headlight brackets not the new ones, they are junk. or at least mine where, I swapped brackets and their fine.
And Blue, these headlights are nice, but i think when the company took their measurements for reproducing them. They must have screwed up because, to me, they are, or at least look thinner then the original ones. When i aimed mine to where I wanted them, I ended up having enough space between the bumper and the new headlight to fit a sandwich in. honestly, i had to aim them down, not by much. but down from where i wanted them. so i don't think it's his fault for having headlight gap.
Re: That Black GTP
I can't use the originals... the passenger light I had in before got completely demolished in the accident. Doesn't make sense to have one secured in headlight and one bouncy one.
I just put weatherstripping on the top and bottom of both lights, they sit snug now.
