Taz Magister
so with this kit your suppose to be able to drop a blower on your N/a without changing the heads and a bunch of other stuff and its kinda cheap everything you need for 750 but because you don't change heads the L67 fuel rail wont work and your l36 wont work because you put a supercharger in the way so zzp says you have to buy there 500+ fuel logs which now make this kit stupid expensive and a fire danger cause everyone says zzp fuel rails leak like no other.
So the question is...Is there any other way to setup your fuel system to work on this without spending 500+?
