lookin good man i want some mori5k bulbs now lol my ddm bulbs suck ass they have some weird yellow shyt in them.....makes my lights yellowish at the cutoff GAY
I've came to the conclusion that its way easier to just use a large cone bit to remove the cross beam. If I have any it's minimal, very minimal.
Looks great Brad..... making me wish I had a black gtp not a red one:th_laugh-lol2:i love them, this man does amazing work.
could you explain this more? how did you remove the cross beam? grind the corners of the projector?
do you mean this ring thats part of the headlight, well at least on mine they are.
awesome thanks, ya im pretty sure these are gm ones, i bought them with the lenses already off. im starting mine right now!
Clean can you post a pic of the rear of your retro'd headlights? Just curious how you 97-03 guys seal the backs up.
Sure thing here ya go,
Notice I mount mine differently than most, I invert the belly of the 3 tab washer inside he belly of the housing, helps to center it better than mounting the 3 tab with raised part out. These aren't finished, dang college hoops keeping me from working on them......
I will RTV a nice bead around the backside of the 3 tab washer and a bead of RTV around the lock ring where it touches the washer. The inside is sealed with the big nylon washer they give you with the hardward. This eliminates any chances of moisture entering from the back of the capsule.
well now you know 2 people. thanks to your instructions they came out almost perfect on the first test fit. drivers side has to come up a little bit and i still have to do the shrouds but they line up nicely.
