Help ! 91 GTP anti loc brake assembly
Rcar1313
HELP ! I just got my 17 yr old daughter her 1st car. A 91 Pontiac Grand Prix GTP. It looks and runs good but needed brake work. Now i find out the master cylinder abs brake assembly is discontinued and none available and very dangerous to change. Mechanics turn it down to work on. What do i do? Cant find the part anywhere!
Ray HELP ! My daughter wants her first car on the road , so do i !
Thx
Ray
help ! 91 gtp brakes suck
Help ! Just bought a 91 gtp with the brake lite and abs lite on. no brakes hardly. The brake booster/ master cylinder is out according to midas.Its my 17 yr old daughters 1st car so she will kill me if i dont get it on the road soon. Been 2 weeks looking for the parts. High pressure discontinued master cylinder/ brake booster is needed, cant find one in junk yards either!
Help ! Thx
Ray
Re: help ! 91 gtp brakes suck
Just get one out of a car without abs and your life will be much simpler i had to do that in my 93 beretta i had.
Any tips on changing it out ? I hear theres alot of pressure and can be dangerous. Also as far as finding a replacement one without ABS, did u use the same year of the car non abs unit? Or how did u match it up to a non abs unit that worked? The brake shop made it all complex getting a correct one to make it work right.
Thx for the help !
Do you still have the car you did this to?
Ray
Thx for the help !
Ray
I just went to the junkyard and walked around looking at berettas and cavaliers from the late 80's early 90's till i found one without abs and cut cut the brake lines on it and yanked it out. To take the one out of the beretta i just unbolted it and cut the lines as close to the master cylinder as possible. There isn't any pressure on it is the pedal isn't pressed most of the time. I just used compression fittings to mate up the brake lines then (I heard your not supposed to use compression fittings but i never had a problem). I had the car for about 40,000 miles after that with no problems at all, i sold it with 230,000 miles on it.
