Yes you can run too much to where the fire line will out run the piston. I would stick to 18-20*.
Drop the timing and pulley down...man I need chipped pistons...does that give me a better running car? LOL![]()
AutoX'ing is pretty legit in a boat...I give ya kudos.
I'd get headers and put a stock pulley on it with a high comp bottom end![]()
How did you know my plans?
Thinking about going SSIC and see about running this 3.6 on that motor.
High compression SSIC and headers you can run a 3.4 Easy. You will want to get 42.5's though
If only I could pull that off.
