question on rims
check for the bolt pattern
the grand prix is 5x115 but you can also put 5x114.3, nothing else exept with adaptors
the offset is probably too low. find the spec's on the wheels and post them up.
also, moving to the right section, watch where youre posting.
Well the tires I'm using are 215/40r17 and if they don't fit I'm going to try and make them I was planning on going to get longer studs and swap them out and use spacers if I had ti I didn't think of doing it like that before the only thing I'm worried about with that is I live in pa and the tires cvant be outside the wheelwell but I don't see why not the tires on my work truck stick out about 5 or 6 inches on either side and they inspected it
bolt pattern and offset are fine, but you need to run spacers or open up the wheel bore since its 60.1mm. Too small for the Grand Prix
