What's wrong with that? I bet if you had gold and wanted to coat something and all you had was a pile of shiit, you would do it.
the bbv solenoid?
If so, you just unplug it and remove it and the vac lines on it.
Just cap off the pressure side and let the bottom nipple of the BBV vent to atmosphere.
Just so you know.... all that does is force you to disable TCS all the time else the car wont be able to pull boost and will pull fuel and timing but not boost.
In otherwords, if TCS isn't off and it engages, you go lean then boom.
Those heads................
