josemolina2008
Who has used this before? I bought it today and tomorrow I'll be applying it to my headlights. Any tips or things to look out for?
Show us some before and after pics, I'm intrested to see if it works.
make sure you have a really good drill. I used it on with a crappy drill, and it didn't do anything.... I later learned my drill wasn't performing all that well...
So, I used a polishing pad and rubbing compound on an awesome drill, and it worked wonders!
I did the same basic thing. No need for these special kits. I used 1500 then stepped up to 2000 and finished sanding with 3000. After the 3000 it was almost clear. Used some polish on it and it looked better than new. Crystal clear.It works pretty good, but, I had better results from using 2000 grit and 3m's polishing compound. The compound I used is about $35 a bottle, but my neighbor works at a body shop and he had some... some good meguiers compound would work too...
^Wow turned out a lot better than I thought it would.
Might need to look into doing this myself...
