'04+ gauges in a '99?
zql8tr
Is it possible to put the '04 and up gauges in my '99 GTP? Are the plugs the same or close enough to change even if the fit might be off a little? I'm really good at fiberglass and could easily make a new dash cover for them.
Re: '04+ dash in a '99?
i think this has been discussed before but im not sure. i want to say no. at least not plug and play. you could probably get a wiring diagram and wire it yourself to make it work.
might want to change your post title. i read it and though it meant fitting the dash from the 04+ into the earlier models. not just the gauge cluster.
Well I searched, but didn't find anything close, just a bunch of random posts with gauges in them... I hate search. You can never find what your looking for as most people type in different words to the same thing, and if it's not 100% the same, you can't find what your looking for.
Also keep in mind the odometer in the 04+ was in the DIC, not the gauge cluster. So even if you managed to get the 04 cluster to work, I dont know where you would store your odometer reading.
Might be easier to buy a 04+ car and live with the ugly exterior...
He's already got ug ug the exterior. An 04+ would be a huge upgrade in all departments :th_nanana:
