Ya I knew you'd say something like that. We all know you'd prefer a 2.5 subaru, dont need to remind us.
I have both, i vote TA though. The opti spark issues are way over hyped, i have had the same opti in my TA for 5 years and changed the water pump right above it and it still works like a champ.
People make the mistake of replacing their Opti's with aftermarket units which is the other reason they go, the geniune AC Delco units are the only ones that should be in those cars.
Agreed. I've had two different LT1's in the past six or seven years and I have never had an Opti issue. It's simple, keep water away from it and it will last forever. A leaking waterpump will leak out the weap hole right onto the Opti (bad design) and potentially take it out. So long you keep an eye on that waterpump and don't hose the engine bay near the Opti it will last over a 150,000 miles. People make the mistake of replacing their Opti's with aftermarket units which is the other reason they go, the geniune AC Delco units are the only ones that should be in those cars.
GTP in a second. Trans Am's are redneck mobiles. :th_shakinghead2: Mullets and Skynard on 8 track, THAT is the air of a Trans Am.
I would rather drive a FORD than a trans am, and let it be known I don't like fords
