bayareagtp
I was wondering if anyone knows how to disable their day time running lights ? Also if there are any pros and cons ? I heard it saves your bulbs so figured I would ask . thanks fellas .
unplugging the DRL module under the driverside is the best way. If you pull the DRL fuse then your automatic lights won't work. I like the lights coming on when it's dark out. Less effort for me.
^Wrong, pull the DRL fuse in the glove box. Doesn't work on some years but i know for a fact it works on 98's.
Part wrong as well... On some models, the DRL fuse absence will sent the BCM into incessant chiming mode. IIRC 1999 and up will have issues.
See my web site.
Same as my 01Mine's an '02. Unplugged the plug from the little box in the access hole with no ill affects, everything still works just fine, just no DRL's.
2 cents
