I have never seen a stock deck with outputs, it's more cost for the manufacturer to add something they don't want you to do anyway. Get a good line out converter and you'll be fine
Its fairly easy, I posted up somewhere on here the tech sheets showing how to take apart everything. I will see if I can find that for you.
I need to know if someone could help me how to hook up the line converter to the back of the stock deck.
Also I was reding on the Contols for the steering wheel I am going to order one of those too
There should be at least 2, sometimes 4 speaker leads coming off the LOC, hook these up to the rear speaker wires or front but rear is easier. Then there should be an accessory wire coming off the LOC hook this up to an accessory wire in the car. Then there should be a ground wire coming off The LOC hook this up to ground.
Depending on which LOC you get, you sometimes get a remote turn on lead output of it so that is one less thing you have to worry about.
-Steven-
