change the key cylinder before your key stops working one day. then it'll be a pain to break it. all you got to do is take off the cover from the steering column. there is a little hole at the top right above the cylinder. turn key onto on position and insert a small allen wrench into it and you should feel a tab. pull cylinder out when you feel the tab pressed down. i think you may have to put car in reverse to disable starter so you can turn key all the way to crank so you can feel that tab.
