Got some wheel questions? In here!!
just want to know if it will fit or not..
my friend have a 350Z with 18"s
245 45 18 to be exact..but if i check on website,his wheels are 20+ offset..
i know that we are supposed to be around 35 mm with 2001 grand prix..
now what will it do? not fit at all? or if i roll the fender it will be ok?
Are they aftermarket wheels? If not the center bore on all OEM nissan wheels is 66.1mm which will not fit.
How wide is the rim? If its 8.5" wide rim it will stick out and possibly rub. If its 8" wide rim it will still stick out but you might be able to get away with it, but I think rubbing will still occur. Especially if your dropped
HELLA FLUSH
18x8 35mm offset (once I set the car on the ground with tires these will tuck in a little) So maybe I'll need some 5mm spacers
the rubber is sitting in the garage...well 3 tires...waiting on a 4th...I bargain hunt.
but I have michelin pilot sports going on them
that looks absolutely awesome. cant wait to see it when its done. hopefully ill be getting my wheels fairly soon as well.
20X7 1/2 on 245/35/zr20 kumho ecsta AST's , absolutely no rubbing on stock suspension. however im back on stock tires and wheels now cuz i wanna go fast and have a bent lip from potholes. 20's look sweet on these cars but if ur going for performance i wouldnt recommend them unless theyre super light
Im wanting to buy new rims but keep the stock tires.
The rims im looking at are 16X7 bolt pattern 5X115 with an offset of 40
... would this work or nahh? Im puzzled because the tires are 6.5 i believe but the rim is 7 so i dont think it will. can someone confirm this?
not enough wheel choices to make it worthwhile to use. tire rack also has a similar thing on their site.
Does anyone know the sizes for a 2006 grand prix gxp? I know that my stock wheels are 1" wider in the front then the rear......please help
