BoostJunki3
Needs A Turbo
so if want to put in an alarm you need to bypass the Passkey system....you have to buy a module for this....buuuutttttt no if you have a starter kill in your alarm the igntion is disabled while the alarm is armed anyway so whats the point of pass key? i found an easy alternative....take your key and cut along the sides of the rubber with a razor blade and find the chip inside....remove it from the plastic retainer in the rubber mold. next take it and electrical tape if VERTICALLY against the passkey box and boom no more passkey.....you can use any copied key you want and can still use the original and with the rubber moved it makes for a kinda cool lookin key....pics below....hope this helps some people
chip
VERTICAL remember!
chip
VERTICAL remember!
