was cruising and doing some spirited driving on the way home on the highway at 1AM in the morning. was only applying like 35% throttle when i felt and saw the car free-rev. i let off and waited a couple seconds then i applied throttle and it appeared to be alright but suddenly it free revs again and i lost 4th
. coasted off to the shoulder and to a complete stop. tried to apply throttle again in D and it didnt budge. i shifted the gear selector to 3 and still no good, then 2 the same and finally gear 1 and the same result. so i decided to shift it to park and turn the car off but when i tried to shift it to park it wouldnt budge from gear 1!!!!what makes it worse is since its stuck there i cant take out my key
:th_wtf:??? another problem is since i turned the car off, i cant seem to start it up again. the system primes but it wont crank.
i was on a slight incline and if i let go of the brakes it'll start to coast since i guess the cars somewhat in 'nuetral'. i applied the parking brake and checked under the hood. checked fluid level and color and nothing wrong, no leaks and i checked the tranny clip just in case it was broken and/or torn. everything looked 'normal' i didnt really hear any whining noises b4 this all happened. im guessing my tranny's toast and where i assume, after some researching, i snapped the chain?am i in need of another tranny? is there any way at the current moment to to remove the key from the ignition? i tried every possible way to try and start the car but it wont:th_wtf: my remote start wont work, i tried disconnecting the battery for a few minutes and i even tried to jump the the starter selenoid and still wont crank:th_shakinghead2:
