I want to thank jbamonte very much for posting this. Since finding this discussion I have found quite a few others having to do with using some combination of shift kit and cooler to take care of this problem. (Here is one good one if anyone is interested:
4T65E Trans Shift Hard, P1811 DTC - Automotive Message Forums)
I'm not actually a grand prix owner - mine's an Oldsmobile Silhouette - but it has that awful, trouble-prone, 4t65e in it and it has been doing the 1811 harsh shift/pump whine thing.
I came across the Triple Edge Performance website which is fantastic if you don't know it (
Triple Edge Performance - Home Page) and assumed I needed a new PCS.
But then I kept seeing people who'd had this replaced, sometimes multiple times, without remedy. I don't actually think that this problem necessarily involves the PCS. I think sometimes it probably does. (Ok - technically it always does b/c the PCS does the pressure, but I think in many cases it is just faithfully doing what it is told).
I have read A LOT of threads by now (its practically been my job the last several days). After learning the story with this I have driven the van a lot while paying specific attention to what is going on with the shifts. This thing basically has sloppy 1-2 and 2-3 shifts. (My wife usually drives it so I never know what is going on). I think that, at least in my case, the code setting is legitimate - rather than from a dirty or shorting out PCS. But my trans has only 70K on it. It has been used like a typical "soccer mom" would use it - a lot of highway, rural highway, suburban roads - i.e. it has not been abused. It has also been serviced 2x in its 70K. It should not be doing sloppy shifts. I think that weak accumulator springs make perfect sense.
Anyway, I think that this is the case for many people and the PCS is not necessarily always the right fix.
I think that sometimes jbamonte's solution may be the right thing - not a shade tree band aid. This is us getting stuck with terrible GM design - in the same way so many people got stuck with DexCool and bad LIM gaskets - and finding a way to fix what they wouldn't or couldn't. This has been my first and last GM vehicle. Junky in more ways than I can count.
Anyway, I recently ordered a shift kit and cooler (I went with the Transgo shift kit b/c I'd seen lots of people recommending it over the others). I'll report back about it. Maybe I'm completely wrong. But even if I'm not, and by #2 & #3 clutches are plain old worn out, all the more reason not to go GM. They made a crappy, problem prone motor (I have piston slap too). And a crappy, problem prone transmission.
