I shouldn't even post right now since I'll probably say something that will jinx me - so I guess I'll just knock wood where appropriate.
I finally got on to the shift kit this morning. (Didn't make it to the cooler yet - both the missus and I had places to go. I scouted strategy for it and will get onto it soon).
It really is a very straightforward thing to do. (Here is a great link with pics - not mine but I perused these as well as others:
http://www.grandprixforums.net/shift_kit.php). This one is done during a rebuild with the trans out of the car.
The only part that I found difficult/annoying was getting the metal lines back in. They flop around a lot and getting all three lined back up was just annoying. It's also just weird because they don't really seat in there - they just sit in with no real positive engagement. It left me very uncertain as to whether I had it right, but there's really no other way for it to be. Given their shape and orientation they couldn't have been in any more or less or any differently. It just seems like plug and pray, but I guess they're not supposed to seal up on there tightly.
As noted, I had the Transgo shift kit. This one was $50, but it comes with a bunch of springs in addition to the spacers. If I had it to do over again I'd spring the extra $40 or so for the Thrasher kit. The biggest reason is just that:
- a) it seems to come with better instructions (the Transgo is really meant to be put in as part of a rebuild by someone who already knows what they're doing; includes more parts than you use in the 1-2 / 2-3 accumulator; and just has a diagram with pretty much no explanation)
- b) the Thrasher comes with a new accumulator gasket and new piston seals.
My piston seals were actually fine. Nary a nick or any sign of a problem. Even if I had new ones I probably would have left well enough alone. The accumulator gasket was another story. It was usable again (luckily) because all of the sealing areas were fine, but it had gotten stuck a few places around the bolts. I would not do this again without a new accumulator gasket handy.
The Transgo springs are for the underside of the pistons. For the stock springs, there are the narrow, stiff ones on top and larger diameter softer ones underneath. Transgo includes new larger diameter springs that are much firmer, and also additional springs that nest inside the larger one. Three spring go in the 2-3 side and 2 springs into the 1-2 side. This is in addition to the spacers. I actually skipped the Transgo large springs and left the stock. I only installed the smaller, nested springs. The larger ones were very very firm and I thought I'd just go a little conservative. I can always open it up again and swap them out. (The whole shift kit job took only about 2hrs - call it 3 once you're done adding/checking fluid, test driving, cleaning up, etc.)
Anyway, I buttoned it all back down, filled it up with Coastal Dex VI, and one 10oz bottle of Lubeguard red. (I have seen more than one transmission tech/rebuilder saying it is great and they use it in everything. One of its stated functions is to aid heat transfer and increase cooling. I have no idea - just going on faith).
So mouth dry and heart pounding I fired it up, put it in gear and thankfully it went. Its actually kind of strange because it doesn't really feel that different - I was sort of expecting harder shifts, but they're not. They are faster though.
Anyway I'm not going to report much for now b/c it is obviously too soon to say anything - but here is where I will knock wood anyway - today was an unseasonably hot day in Central VA. I spent a portion of the 5:00 period in a long line of stop n go traffic with 96 showing on the van's thermometer. In addition there was quite a bit of winding back road driving today. Fretted a lot ... waiting to yell "FFFFUUUUU... dge." But didn't have to... at least today. I'm knocking wood again. I'll stop back in at some point after I have some miles behind me and the cooler installed.
