Maxima rims
Okay I've been looking for 2010 Nissan Maxima rims for the GP. I thought they were all 18"s with a 5x114.3 bolt pattern. Turns out there's a nice set of 19"s on the Maxima SV, but the bolt pattern is 5X108. Why the 2 bolt patterns?
Otherwise I'd be getting these:
19 Inch OEM Nissan Maxima 09-10 Rims Wheels Set Of 4 : eBay Motors (item 200462255126 end time Apr-23-10 17:30:00 PDT)
no no...that bolt pattern is totally wrong. I know guys who are running those rims on their Maxima's with 5x114.3 pattern. But the reason these won't fit at all on our cars is Nissan tends to use a hub bore of 66.3mm and we need a 70.3mm or larger bore on a rim
He even says in the ad, 4.25 bolt pattern meaning 114.3
yup, the wheels will fit
but you will need to either open up the bore or run some 10mm spavers with longer studs.
