nascartech
hey guys just wondering if any one with a l36 has seen any gains from porting there lower intake manifold and if so what gains thanks
porting what about it?
'porting' the inlet will make no differences since you dont need it opened anymore.
porting the outlets going into the heads will make a step down from the LIM to the heads, which you dont want.
so all im getting at: no gains for you.
Tip: If you are doing this you should block the coolant flow to the TB by plugging the top of the LIM and then remove to coolant bypass plate on the side and port that a bit for better flow then replace the plate.
I do not have any pics of opening the coolant passage but when you have the plate off you will be able to see a part that looks like the top of a "T." You will cut it down to look more like an "l".
When you get the plate off it will explain its self.
