ls6velless454
I bought this 2000 GTP about 2 months ago and the car has 115000 miles on it. The guy I bought the car off of said he replaced the maf sensor. For some reason when I go to start the car it will start and turn over, and then misfire really bad. Earlier the car smelled like gas. The main thing I noticed was when it was missing and running badly the car was making a loud intake noise. This happened once last week and of again this past week. I went and checked the alternator and battery. They both tested good, and checked to see if it was throwing a check engine light, and it passed with no codes. The weirdest thing is that car will run good......then out of nowhere idle at 500 rpms and then die, and the only way I can start it is by giving it gas. So the car will miss and die and then out of no where start running normal again. I'm assuming because these conditions it's gonna either be the maf, because they replaced it with a bad reman, the tps, or map sensor. When I got to my girlfriends the car started running good again, and I unplugged the maf and the car still runs the same with no check engine light codes. Can someone please help me out here.
