killakross5o4
ohh mine are done.... i got mine in... but i will tell u right now to send urs back.. it took me 3 hours of mock fitting,cutting and welding to get it just right....see the front header where the 3 pipes meet...that needs to be angled up about 3 inches to make it over the trans... what i did was welded 3 inches of pipe on it to shoot it up and overthe trans...then on the cross over part i weld another pipe on it with a hook shapped bend to make it go over the trans and under my air intake...and i had to use a buddys pipe bender to bend the pipe a hair to move around the trans dip stick... i almost weld the y collector FIRST to the back mani..then put the back mani in..then the cross over to the y pipe... then the put on the front mani..its ALOT easier to get to the back side if u undo the 2 front motor mounts..and put a piece of wood on a jack and jack up the back side of ur trans to tilt/ push ur engine forwards....if you want send me ur headers and ill weld the pieces they need on ur front mani and ur downpipe... i still have my mock ups..let me know...but i wont pay for shipping to u
